Old 07-25-2017, 07:53 AM   #1
Axle nut torque
I know the value to torque new Axle nuts is 340 Lb-ft, but...
I recently removed front wheel hubs and replaced wheel bearing. I knocked out a few worn items while in there, such as tie rods, lower control arms and drop links.
I bought new axle nuts and torqued to correct value got a wheel alignment and all is well.
Question: Why is the front axle nuts torque specification such a high value? All they hold on is the stub axle. I can see the high value on the rear where you are connecting the drive axles to the hub, but the front sure seems like overkill. My guess it its a 'left over spec from the 996 4S cars...same hub and nut I would guess.
What am I missing?
Old 07-25-2017, 09:10 AM   #2
Filastein's Avatar
Torque is, by and large, a value of the size of the fitting. Big thread diameter = big nut = big torque.
That and Porsche's desire to limit part count. I believe the front hub is the same part as the rear, just with different hardware behind it.
2 0 0 1 S
Filastein is offline   Reply With Quote
Old 07-25-2017, 02:59 PM   #3
lkchris's Avatar
Exactly.
And, when you tighten something to a torque value, you are stretching or distorting the component, creating permanent tension. Takes big power to do this to a big part.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 07-25-2017, 11:47 AM   #4
What am I missing?
dghii,
I believe that the high torque is required to keep the dual row bearings together.
Old 07-25-2017, 01:51 PM   #5
I hope not!
Old 07-25-2017, 02:25 PM   #6
steved0x's Avatar
The clamping force on the inner races is important, the friction of the 2 inner halves on the hub is nit enough, it is why you are not supposed to roll the car with the axles out.
