Old 07-25-2017, 06:06 AM   #1
what is it?
Found a black 4" long about 0.5" diameter tube with wires attached hanging from N/S front of 986 right near the plastic trims that extend under the wheel arch liner. Does any one know what it is please? I noticed a rusty clip on it and it seems to have broken off. My idea was it could be a temp sensor for the radiator or? Ideas please...
DaveBBOXSTER is offline   Reply With Quote
Old 07-25-2017, 06:21 AM   #2
911monty's Avatar
Hmmmmm. IV drip or the capacitor for the radiator fan.......Run over anything lately? If not then capacitor.
Old 07-25-2017, 06:28 AM   #3
If it has green and white wires attached to it, it's the low speed fan resistor
Woody
Old 07-25-2017, 06:31 AM   #4
JayG's Avatar
A pic would help
Old 07-25-2017, 06:31 AM   #5
911monty's Avatar
OOPS you're right. Not enough coffee yet! Resistor, Capacitor oh well.
Old 07-25-2017, 06:54 AM   #6
Old 07-25-2017, 06:59 AM   #7
Thanks everyone you guessed it without a photo...Is that rusty metal behind it my actual car chassis or some cheap sub-frame cross member!!!
Old 07-25-2017, 10:03 AM   #8
Wow are your roads made of salt out there?!? I've never seen that bracket that rusty before. On another note, your resistor looks like it's about to go out if it hasn't already. They get dark like that as they age. "generally speaking"
Woody
Old 07-25-2017, 10:12 AM   #9
I think he lives in England. Everything rusts in England.
2003 Boxster S
1991 BMW 318is
'93 Ducati 900SS
'76 BMW R75/6
'73 Honda Scrambler
Kurt V is offline   Reply With Quote
Old 07-25-2017, 12:47 PM   #10
Yes I am in the UK...So that rusty metal is just a bracket? So glad it isn't the bodywork.
And maybe the 'low speed fan resistor' is on the way out? What may happen if it goes then - do the fans on the radiator stop are there fans on them?
Old 07-25-2017, 02:03 PM   #11
lkchris's Avatar
Yes ... check out a Land Rover magazine or forum.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 07-25-2017, 02:05 PM   #12
Your fans won't work at low speed. Only high.
Woody
Old 07-26-2017, 12:18 PM   #13
Thanks Woody - does that mean there are two fans at the rear of the radiators? I know there is one for the engine bay
Old 07-26-2017, 12:59 PM   #14
No need to answer last question Woody just seen photos on Pelican Parts showing fan and resistor in place so now know where it fits on
Old 07-26-2017, 01:11 PM   #15
Also found the radiator support part that is badly corroded $300 for two
Old 07-26-2017, 01:37 PM   #16
Please don't spend $300 on the radiator brackets. I sell them for $10 each. Guessing shipping to the UK would be $50-75
Woody
Old 07-26-2017, 08:31 PM   #17
There is only one fan for each radiator. The resistor simply reduces the amount of current reaching the fan motor to create the "low speed", thus when the resistor fails, full current is continuously sent to the radiator fan and it always operates at high speed only. If one of the radiator fan resistors fails, the other side is typically not far behind.
The engine compartment fan is completely different.
