Old 07-01-2017, 03:18 PM   #1
Cool CEL after 6 years
Just after I bought my Boxster S 6 years ago it through a CEL, a completely new arena for me. At the time I put the car on the ramps and found both os's on the cats were loose, I tightened them up and that solved the problem. Did the disconnect battery thing to get the light off.
6 years later, yesterday in fact the CEL came on. There is no noticeable difference to the running of the car. It always pulls like a train without hesitation and its no different now with the light on. At this point I might add that I do all my own maintenance of my car. Having said that I have steered away from diagnostic equipment and up to now have managed fine. I had the car on the ramps today and there is no loose os's and it sounds sound sweet underneath with the motor running and there is nothing i can visually see wrong.
I'm cornered now so two questions, is it worth asking what any of you guys think it could be? Also it seems like I am forced into considering purchasing a diagnostic tool, which one though, its not my area? I do want to continue doing "all" my own maintenance.
derfo is offline   Reply With Quote
Old 07-01-2017, 03:20 PM   #2
Durametric
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is offline   Reply With Quote
Old 07-01-2017, 05:21 PM   #3
Artist, 986S tinkerer
NewArt's Avatar
Durametric is certainly a favourite, however others have supported other ob2 diagnostic tools which sell for less. Do a search. You'll probably find a variety of opinions.
Old 07-01-2017, 05:30 PM   #4
Just get a cheap OBDII reader.
No sense in randomly poking at things.
Old 07-01-2017, 05:31 PM   #5
Don't know if any of the shops in the UK operate like some in the US loaning out an OBD2 reader in exchange for the chance to sell you something to fix the car. Without knowing the exact code, we'd be guessing.
Old 07-01-2017, 08:54 PM   #6
kirkandorules's Avatar
Seconding just getting a bluetooth ODB2 reader. Mine was $10 US on amazon. You can read the codes with any number of free apps, and then search on these forums for further info on what they mean.
Good luck, hope it's something simple - if the car feels totally fine, chances are pretty good that it is.
kirkandorules is offline   Reply With Quote
Old 07-02-2017, 07:05 AM   #7
I very strongly recommend getting a reader that can read the Porsche-specific codes. There are a lot of things that can go wrong that won't be revealed with a generic OBDII reader, some of them can lead to catastrophic failure, like camshaft timing.
Obviously the best choice is Durametric, but there are readers in the $100 to $300 range that will read vendor-specific codes. I got one of those because I have both a Boxster and a Mercedes CLK 350 convertible and with this I can get away with one reader instead of two.
When you service the car it takes little effort to read all the codes and get a feel for the condition of the critical systems.
1941 Dodge Luxury Liner Coupe
Old 07-03-2017, 01:22 AM   #8
Thanks everybody for your comments and suggestions. I will try and post again when I get a bit further on.
Old 07-03-2017, 05:33 AM   #9
I am No. 1348
algiorda's Avatar
If a Durametric reader can only read Porsche vehicles, what do I use to read codes from my other vehicles in the family like my Miata, Dodge Caravan, Honda Civic? Do I need to have TWO code readers?
algiorda is offline   Reply With Quote
Old 07-03-2017, 06:57 AM   #10
I have an Autel Maxidiag MD802 for my Boxster, Mercedes CLK 350 and Prius C. Just under $200. Very happy with it.
Old 07-03-2017, 08:22 PM   #11
I love my Autel, especially because it can read and reset ABS codes. I addressed the infamous seatbelt buckle/ corroded connector issue last year shortly after I bought the car and recently the clock spring gave up so replaced it and reset the light. Already paid for itself if I went to the stealership to get charged $175 hourly labor for 5 min work a few times.
Old 07-04-2017, 03:39 AM   #12
Hello Anker
Is your MD802 a 4 systems or all systems?
Old 07-04-2017, 05:46 AM   #13
Originally Posted by derfo View Post
Hello Anker
It is lots of manufacturers, not just 4.
Old 07-04-2017, 09:40 AM   #14
Hello Anker
On their website it says the MD802 can be purchased as a 4 system or all systems tool. This means systems on whatever car it is. The all systems tool is a little more expensive.
Old 07-04-2017, 10:29 AM   #15
So I must have the all systems version.
Old 07-04-2017, 11:20 AM   #16
Code reader
Ideally Durametric is the best choice. I have a Durametric, another general purpose reader and a cheap blue tooth reader. The one I use the most is the cheap blue tooth reader w free software. At least you can read the codes as a starting point. If the cheap unit can't read or reset the code then you could look into Durametric. I have a vacuum leak code that pops up from time to time and when the CEL comes on it's easy to check if it is something more serious and a quick reset from cell phone.
opus69 is offline   Reply With Quote
Old 07-18-2017, 10:21 AM   #17
Cool Diagnostic tool
Hello everyone
I know as some of you pointed out and from what I have read that the Durametric is probably the best after market tool for Porsche cars. Its Porsche specific I believe. The one I chose after reading about it (prompted by Ankers purchase) was the Autel MD802 all systems tool. I chose this in the end because it seems to cover so many vehicles as well as Porsche.
I tried it out the day after I got it and it found the fault right away. It read "P0139 sensor aging behind cat c bank 1". So it looks like I need a new 02 sensor on that side because the old one is tired.
This is early days I know but it seems simple to use up to now.
Old 07-21-2017, 12:03 PM   #18
Cool Replaced 02 sensor
Hello everybody
I just thought I would post how things are going. I replaced the 02 sensor on the drivers side. In the manual for the Autel tool it says you can delete the codes, which then I assume the CE light goes off. That is what I was going to do when I got home from work. On the way home however the CE light went out itself. I suppose this tells me that the new sensor works and is communicating the right info to the DME.
My question would be then, does this happen to all repairs of sensors, is it best to wait for the light go out itself after the repair or replacement. Or doesn't it matter.
This is all very basic stuff I suppose to all those of you who have been using diagnostic tools for years, but to newbies like me, its a big learning curve.
Old 07-21-2017, 02:49 PM   #19
Hello everybody
Works with some MIL lights, but not all. Some have to be manually reset.
Old 07-22-2017, 04:23 AM   #20
Cool MIL lights
Thanks JFP, I will bear that in mind. Is MIL an American abbreviation?
