Code reader
Ideally Durametric is the best choice. I have a Durametric, another general purpose reader and a cheap blue tooth reader. The one I use the most is the cheap blue tooth reader w free software. At least you can read the codes as a starting point. If the cheap unit can't read or reset the code then you could look into Durametric. I have a vacuum leak code that pops up from time to time and when the CEL comes on it's easy to check if it is something more serious and a quick reset from cell phone.
