Old 06-11-2017, 05:47 PM   #1
Headlights Don't work
Both headlights, high.low. fog & indicators have stopped working. Checked fuses & they are ok.
What else could it be?
I'm thinking maybe an earthing problem?
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 06-12-2017, 04:00 AM   #2
2003 Base 5-speed
grc0456's Avatar
You may need to replace your headlight switch.
Old 06-12-2017, 04:26 AM   #3
I believe it also could be the ignition switch!
1941 Dodge Luxury Liner Coupe
Old 06-12-2017, 10:28 AM   #4
Replacing the headlight switch solved the problem for me, although Anker is correct -- could be the ignition switch as well.
Need_for_speed is offline   Reply With Quote
Old 06-12-2017, 10:40 AM   #5
Headlight switches are very expensive and usually just need a cleaning. Order an ignition switch because they're not expensive and you'll need it eventually, anyway. While you wait to receive the ignition switch, clean your headlight switch snd see if that solves your issue. If not, install the new ignition switch.
If neither helps, you may need a new headlight switch.
My money is on the ignition switch.
Old 06-14-2017, 06:36 PM   #6
Thanks Guys.
Looks like it's actually the connectors to the lights themselves
2000 2.7 Boxster
Old 06-15-2017, 12:29 PM   #7
Aussieboxy - can you share what the issue was and how you fixed it?
On my left headlight the litronic low beams work, but fog, high beam, and blinker do not. Right light is fine, fuses are fine.
I'm guessing I may have a connector issue, too.
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
