Old 06-12-2017, 11:40 AM   #5
particlewave
Headlight switches are very expensive and usually just need a cleaning. Order an ignition switch because they're not expensive and you'll need it eventually, anyway. While you wait to receive the ignition switch, clean your headlight switch snd see if that solves your issue. If not, install the new ignition switch.
If neither helps, you may need a new headlight switch.
My money is on the ignition switch.
particlewave is online now   Reply With Quote
