Old 06-14-2017, 05:46 PM   #1
You are imagining things. Pumping the pedal has zero effect on starting. That only worked on carbureted engines with acceleration pumps. :-)
1941 Dodge Luxury Liner Coupe
Old 06-15-2017, 08:01 AM   #2
Rennzenn
j.fro's Avatar
My bet is that you've got a vacuum leak. First thing I'd check is the oil filler tube.
Rennzenn
Jfro@rennzenn.com
Old 06-15-2017, 08:35 AM   #3
Not true on a '99. Pressing the pedal opens the butterfly on the throttle body (he has a cable throttle).
Sounds like an EVAP regeneration valve based on the symptoms. Could also be CPS, MAF or fuel sending unit.
Is it hard to start after fueling, or only when hot?
You say "we just replaced the sensor"...which sensor?
Here's a good post on the regeneration valve:
Success! Finally fixed the hard start while hot and fueling issues.
