Old 06-09-2017, 06:28 PM   #1
Boxster Starting Issue
Anyone have an idea why my Boxster has trouble starting and stay running when it is warmed up or is a hot day? It sputters and dies off if I don't keep it revved up for a bit, then it will run fine. This only happens on start when it is a warmed up engine or on a hot day.
Note: The Air Mass Sensor has been replaced and still happens.
Denham33 is offline   Reply With Quote
Old 06-10-2017, 11:54 AM   #2
What codes does it show.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-10-2017, 01:19 PM   #3
There Is No Substitute.
rick3000's Avatar
Can you elaborate on the sputtering? Is the car turning over, then the idle is out of whack and it stalls, or do you mean that the starter is sputtering and it never turns over?
What year is it? Any codes, other issues?
A failing CPS will often not throw a code and will be finicky when hot, other suggestions based on limited info: fuel pump, or a very dirty throttle and/or control valve. Again, these are guesses based on limited information.
Old 06-14-2017, 12:38 PM   #4
The car is 1999 Boxster. It turns over fine. Rather than instant start it takes a few seconds and helps if I pump the gas. It runs fine once started. Not sure on codes. The check engine light has come on now. We just replaced the Sensor.
Old 06-14-2017, 05:46 PM   #5
You are imagining things. Pumping the pedal has zero effect on starting. That only worked on carbureted engines with acceleration pumps. :-)
1941 Dodge Luxury Liner Coupe
Old 06-15-2017, 08:01 AM   #6
Rennzenn
j.fro's Avatar
My bet is that you've got a vacuum leak. First thing I'd check is the oil filler tube.
Rennzenn
Jfro@rennzenn.com
Old 06-15-2017, 08:33 AM   #7
Do a resistance test(hot) on the CPS
Old 06-15-2017, 08:35 AM   #8
Not true on a '99. Pressing the pedal opens the butterfly on the throttle body (he has a cable throttle).
Sounds like an EVAP regeneration valve based on the symptoms. Could also be CPS, MAF or fuel sending unit.
Is it hard to start after fueling, or only when hot?
You say "we just replaced the sensor"...which sensor?
Here's a good post on the regeneration valve:
Success! Finally fixed the hard start while hot and fueling issues.
