Old 05-26-2017, 07:38 AM   #1
unknown connector
Now that I have my vacuum lines taken care of, aos & both bottom/top hoses done, I finally have my intakes back on. On the driver side though I spent the past hour scratching my head. Can't figure out what this connector is supposed to connect to.
I have the 3 connectors for the injectors, but this 4th one past the end of the fuel rail toward the trunk I can't find what it should connect to. It is a 2 wire connector
Old 05-26-2017, 08:53 AM   #2
Fuel Evaporative Valve (Tank vent), just under the rear of the intake manifold.
RodJ is offline   Reply With Quote
Old 05-26-2017, 10:12 AM   #3
When this is disconnected as in the photo, you should get a Code?
Old 05-26-2017, 12:27 PM   #4
Is it attached to the block or attached to the underside of the intake? Thought i had the one on the underside of the intake connected, but very well could of missed it since it's a pain to get to anyway.
Old 05-26-2017, 04:11 PM   #5
Well, it's not what is attached to the underside of the intake, I have connected.
Any other ideas?
Old 05-26-2017, 04:51 PM   #6
Thanks to Woody....I have the wrong connection to the evap, it should go to the gray changeover and the end connector goes to the evap
