10-20-2018, 12:07 PM
#181
Here is what a V8 fits like inside the engine bay of a Boxster using the factory 5-speed transmission and transmission mounts. The front of the engine is not in the correct position as it sits too low. I believe this is where the 'cutting' of the sheet metal that was mentioned before comes into play. There is also no space for the air intake duct at the back of the engine.
This is how I hoisted it up into place. I used a ratcheting strap to adjust the pitch of the engine.
10-20-2018, 12:09 PM
#182
This is as high up as the engine could be lifted. Major interferences at this point wasn't even between the top of the IM and the engine room sheet metal but rather the timing belt covers and the angled part of the 'firewall'. At this point the oil pan was approximately 2" lower than the H6, and the transmission was noticeably angled downards.
10-20-2018, 12:11 PM
#183
You can see the throttle body opening in the top of the picture (I have a ziploc bag over the TB):
Also shown is the interference between the RH side variable cam actuator and the engine cover quick-turn latch.
10-20-2018, 12:13 PM
#184
This shows the interference on the LH valve cover and the engine cover quick-turn latch.
10-20-2018, 12:19 PM
#185
So does anyone have a chain drive V8 available that they want to drop off at my house for a test fit?
10-20-2018, 08:38 PM
#186
That's about how mine looked. I cut the tabs off and beat the front firewall out a bit with a hammer to get better clearance for the timing belt covers. The next fitment problem that I have to figure out is how to run the shifter cable. I still haven't really tried to solve it yet, but mine runs a little short after going around the V8.
10-21-2018, 02:31 PM
#187
What are you going to do about the throttle body inlet? Have you thought about flipping the IM around so the TB faces the front of the engine and then bashing the firewall some more?
10-25-2018, 10:44 AM
#188
I built a whole new engine cover. There is no easy way to keep the dip at the back of the engine cover, I cut all that out to give space for the intake. Once it is gone, you can get a better angle on the engine with the stock trans mounts and most of the upfront clearance issues go away.
I used 6 speed Cayman cables and ran them around the sides. No good for a street car, but for a race car it works perfectly. No way I could see running them over the top of the engine would work, so I split them left and right for a 6 speed trans, and ran them both to the RHS for a 5 speed.
11-01-2018, 05:41 AM
#190
Gavin, I didn't see you at Hallet. Are you going to make it to COTA?
Woody
11-23-2018, 07:51 PM
#191
Bump. What happened to titaniumdave?
I've got a 4.2l S6 motor and ecu heading my way. Hoping to have this completed by next track season
02-18-2019, 06:57 PM
#192
If anyone in Ontario has a hoist and wants to do this to their car, I'll design the parts, get them fabricated, and do the wiring. You supply the V8 and the Boxster (preferably a later model 986).
I know you've already started your build, but would you by chance want to so another one in parallel? Always wanted a V8 986, but don't have the space nor skills to make it happen. Would be happy to supply car, Audi front-cut/parts car and etc. Thanks!
02-19-2019, 07:44 AM
#193
INFOSEC Ninja
This thread, among others, has me wanting to do this swap to my Boxster. So far, I've got an S8 AYS engine and a Cayman S 6 speed transmission. Next step is to sell the 2.7L.
'03 Boxster with an Audi S8 4.2L V8 - https://sites.google.com/view/boxsterv8swap/home
'06 Cayman S Tip
03-04-2019, 03:17 PM
#194
Meh, this thread is kind of the opposite for me. Two years on and no one in the thread has one up and running? And the guy talking about making a kit has gone awol?
03-04-2019, 04:38 PM
#195
Yup, all for the glory of having an Audi motor in it because it shares German blood. Should just LS swap it and be done.
Mine was lots of fun, maybe one day i'll do that budget swap I was wanting to do...
John or J.J. - But I answer to most anything~
*2000 Honda Accord 4DR V6 - 220K*
http://986forum.com/forums/show-tell-gallery/54328-boxsterls376-introduction-ls3-conversion.html
03-04-2019, 07:50 PM
#196
"Just LS swap it and be done"
Oh that simple eh? Was it your build thread where there was multiple pages devoted only to the cutting and welding required to get the LS to fit between the seats and the transmission?
I've gotten a decent amount of research and trial fitting with both the V8 and V6 engines. I'm at a point where I can start designing and fabricating mounts/frames/etc.
However, I'm holding out on my own swap until I can find a decent Cayman S transmission - the way I look at it is that there is no point doing the swap with the Boxster 5-speed since you'll be limited to around the same sort of power a Boxster S makes from the factory anyway.
03-05-2019, 01:11 PM
#197
Mine is running and has been for a while. Not a great solution for a road car, but not too bad a build for a racecar.
Biggest problem I've been facing is keeping it cool - think i have that solved now with a turbo center radiator and high quality aluminum side radiators.
The big advantage for me putting an Audi motor is is that it is legal in NASA GTS racing.
03-05-2019, 05:02 PM
#198
Fellow NASA guy here. Do they consider it the same manufacturer?
2003 911 C2
NASA HPDE Instructor
03-05-2019, 05:28 PM
#199
NASA GTS allows engine swaps within the same "family" i.e if its in the VAG group its fair game, so you could swap a Bugatti Veyron engine into a Skoda fabia and it would be GTS legal. Putting a Mercedes sprinter engine in a VW Caddy however would not be legal.
03-18-2019, 02:01 PM
#200
I'm planning on putting 450bhp through my 5 speed, wish me luck.
