Old 02-17-2017, 07:11 AM   #1
I am No. 1348
algiorda's Avatar
Interested in installing Ceramic Pads, any input?
My brakes seem a little spongy and I plan on doing a fluid flush and pad replacement.
I'm pretty much sick of the brake dust on my wheels and I'm considering Ceramic pads which I have on my Cadillac. They perform well and do not emit any dust.
Anyone have experience with Ceramics and can recommend a decent brand?
I have a 2004 S Special Edition.
algiorda is offline   Reply With Quote
Old 02-17-2017, 07:32 AM   #2
JayG's Avatar
What kind of driving are you planning on doing
street
AX
track
I run different pads depending on what I am doing
For street and sometimes AX, I have been using PowerStop ceramics they stop on a dime and give 5 cents change.
They are fairly inexpensive, ~ $35 an axle on amazon
https://www.amazon.com/dp/B003YOCLWY/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3HC0TWCL7KNZJ&coliid=I2NWZTXPGSWVT7
https://www.amazon.com/dp/B007K1KZLG/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=3HC0TWCL7KNZJ&coliid=IHPX9WKRAKLGQ
ENC RedStuff is also a great pad. You can spend a lot more $$ and not get any better performance
For track, I use otherpads
Old 02-17-2017, 08:55 AM   #3
I am No. 1348
algiorda's Avatar
Thanks Jay,
Just using the Box as a daily driver right now, although I do live within striking distance of Sebring. I would re-evaluate the entire vehicle for track use, but not very likely with what I consider a somewhat collectible vehicle (although some may disagree).
I like your choice in pads, they look very good. Do you think I should also evaluate the rotors when I switch to Ceramic or is that a non-issue.
Old 02-17-2017, 08:50 AM   #4
Ceramic pads will greatly reduce brake dust and most stop as well or better than the OEM pads. I used EBC Redstuff but there are many well known brands to choose from.
Old 02-17-2017, 08:54 AM   #5
Rennzenn
j.fro's Avatar
+1 on EBC Redstuff pads.
Rennzenn
Jfro@rennzenn.com
