10-17-2016, 05:00 AM
Is there a wind noise fix how too?
I've got a terrible wind whistle on my 986. I mentioned it previously as I didn't notice it until after having the front end repaired and was told the frunk (front trunk) fit is critical. I've messed around with it for a while, screwing in the rubber stops to make sure the hood is under flush with the front bumper, but no joy.
It seems to start around 55 and goes away some time over 75mph. This morning I came it to work at 6:00 when not many people were on the road. I came in at speeds up to 85 and didn't hear it until I was slowing down into the 60's. It doesn't seem to be totally repeatable, but it's driving me nuts.
Is there a step by step how too out there on how to set the hood height, or mirror or whatever it might be as it's driving me nuts.
Thanks all.
Budget 1999 986. Not much, but it's mine all mine.
Volvo C30 picked up Euro delivary 6/26/08 drove the Nurburgring 6/30/08
10-17-2016, 05:18 AM
Are you sure it is coming from the hood? There are so many things that
Can cause noise on Any vert. Boxster no different. Almost always something with the top tho, unless it is inside or of Course tires
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
10-17-2016, 07:37 AM
Racer Boy
Try putting duct tape on the hood seams to see if that changes it. If it does, then you know that is where the problem is.
You can do the same thing with the tape on other parts of the car until the noise goes away, and then you've found the culprit!
Just be sure you remove the tape in short order, as it can leave a nasty residue that is difficult to remove.
10-17-2016, 09:00 AM
If you search for 'whistle' on here you'll find others have had noises from the filler cap area and the release valve in there that sound similar to your issue, may be worth checking that out also.
10-17-2016, 10:19 AM
It happens top up or down so I don't think it's top related. Filler cap is interesting though. Off back to searching
10-19-2016, 12:54 AM
Check out this old post.
front latch adjustment
10-19-2016, 10:16 PM
Use painters masking tape instead, the blue stuff. Easy to remove, no residue.
10-19-2016, 10:33 PM
I agree with reviewing the link above - you said you adjusted the rubber stops on the frunk, but you didn't mention anything about trying to adjusting the frunk latch position yet. Try lowering it so the leading edge of the frank sits down a little lower than the bumper relief.
If I recall correctly, you'll need to remove some carpet and/or a plastic trim piece to access the latch bolt heads, and I think they're 10mm. Try adjusting it just 1/8" or so. After adjusting, you'll need to screw the rubber bumpers in/out so the front lid isn't "rattley loose", but also not so tight you need to press down extremely hard to get the frunk lid to latch. (It will take a bit of pressure still to close the frunk lid, though.) Good luck!
2001 Boxster
10-20-2016, 12:54 PM
I think Pedro mentioned that the frunk has to be below the bumper, otherwise there will be wind noises...
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
10-20-2016, 01:44 PM
07 Carrera S Cab
Yes....if you make the trunk sit slightly below the trailing edge of the bumper cover, there will be no noise.
