Old 09-15-2016, 10:13 AM   #1
Cruise won't set
So, I installed the CC hack from Pelican. Got the CC turned on by shop. Light comes on when the key is on. Light comes on when driving. When I pull the lever towards me (interupt?) the green dash light briefly goes out and comes back on when I release the lever. But, if I try to set the speed nothing happens. It is an 03 so the connections are all in the cluster. Can I have some connections ok and others not and still get the light? My next step is to check the 3 wires from the switch to the cluster...maybe I put the pins in incorrectly or missed the correct pins on the cluster plug? Any other thoughts?
Bob
