Old 09-05-2016, 03:23 PM   #1
heaqdlights cause radio static
If I have the radio on with only the driving lights the reception is great. As soon as I go to the headlight position, either low or high my radio goes to static. Any idea of where the ground points of these devices are. I run LED low beams and Halogen highs. So it's not specific to my headlight type.
Any one else have this problem?
n559br is offline   Reply With Quote
Old 09-05-2016, 05:05 PM   #2
It's your LED lights, seen it several times.
Old 09-05-2016, 07:13 PM   #3
With the high beams on, both the low beam and high beam bulbs are used, so anytime the headlights are on, the low beams are on.
Disconnect the LED bulbs and see if the problem goes away.
Old 09-06-2016, 10:56 AM   #4
thanks, I'll give that a try. this Sucks, I liked the LED bulbs.
Old 07-23-2017, 06:24 AM   #5
I'm having the same problem, is there a cure other than changing lights?
Thanks, Dave
Dave
1998 Boxster
1978 R100RS BMW Motorcycle 140K, 1 owner
WhiteyII is offline   Reply With Quote
Old 07-23-2017, 07:55 AM   #6
still plays with cars...
BoxsterSteve's Avatar
Don't drive at night... or take up yodelling.
Sorry, you're going to have to ditch those LED bulbs, my friend. I found the same thing a couple of years ago when I tried experimenting with LED's on my Boxster.
Six speed 2000 Boxster S
Old 07-23-2017, 02:57 PM   #7
Ferrite coils or clips can often help.
