Old 08-28-2016, 12:17 PM   #1
madmodz's Avatar
911 intake on the 2.7 question custom chassis
I read some interesting post on here using the search buttons and am greatful for the brains here and the guys that think outside the box. I am a hot rod and replica builder and prefer the boxster platform for the replicas.
So the 2.7 is greatly restricted by the intake manifold. In my case I am using a 2000 2.7 motor in a CUSTOM car. I don't have any space limitations on top or sides of the engine bay.
(1) That being the case, can I just straight bolt on a 996 intake/spacer manifold with its plenum and throttle body?
(2) Am I limited to using the 986 maf?
(3) Got tons of room for any airbox. What would you recommend?
(4) Underneath I have a lot of room and am running straight pipes with 4 cats at the moment. Instead of an expensive aftermarket, will any other exhaust bolt on?
(5) any other tips you recommend keeping in mind I have plenty of room in the motor compartment
Thank you guys ahead.
madmodz is offline   Reply With Quote
Old 08-28-2016, 12:46 PM   #2
BYprodriver's Avatar
The intake manifold is designed by Porsche to maximize torque thruout the 2.7l rev range. The 3.4L 996 manifold is designed for 3.4L. .7L is a huge difference in airflow requirements. You will lose low RPM torque & if you gain any @ high rpm it will be like the valves, small. A 3.2 Box intake may help if the ports are the same size. If you can tell me the size of your 2.7's runner openings I can compare that to a extra 3.2L I have.
Old 08-28-2016, 07:34 PM   #3
madmodz's Avatar
I got them mounted on already so I won't be able to give you the measurements. I thought the 2.7 and 3.2 were identical manifolds.
Jack Raby had made this quote on another thread: "That 2.7 intake is killing the potential of that engine. The 2.7 intake is inadequate even for a 2.7 engine."
Old 08-28-2016, 08:26 PM   #4
Engine Surgeon
It also won't bolt on.. The port spacing is different, the bolt pattern is different. The 996 uses an intermediate runner set up thats made from aluminum.
US Patent 8,992,089 &
US Patent 9,416,697
