Old 08-08-2016, 01:27 PM   #1
embryoguy@mac.com's Avatar
cost of repair?
I just had my serpentine belt and spark plugs changed. $300 labor. Does that seem about right? Thank you guys for your thoughts!
embryoguy@mac.com is offline   Reply With Quote
Old 08-08-2016, 01:35 PM   #2
still plays with cars...
BoxsterSteve's Avatar
Can't say... I changed my plugs in 1 1/2 hours, all in, and had the serpent belt swapped in a half hour, start to finish.
At that rate, we'd be talking $150/hour.
Six speed 2000 Boxster S
Old 08-08-2016, 01:50 PM   #3
well, you didn't take breaks etc lol yeah Their rate is 90$. I guess 3 something hrs is not too unreasonable.
Old 08-08-2016, 01:55 PM   #4
I assume your a weekend mechanic so I would hope they would be faster then you are at fixing things
Old 08-08-2016, 02:04 PM   #5
Did the $300 include the parts? If yes then the repair was probably 2+hours.
Old 08-08-2016, 02:42 PM   #6
$300 labor, 125$ parts (oem plugs, tubes, engine air filter), I supplied serpentine belt.
$25 tax
450$ total.
Old 08-08-2016, 02:55 PM   #7
911monty's Avatar
$25 tax
450$ total.
AHH HA!!! You didn't mention the tubes were changed in the first post. With that also being done then $300.00 is reasonable.
Old 08-08-2016, 03:09 PM   #8
oh is the tubes that difficult to change out also? ok Thanks makes me feel better
Old 08-08-2016, 04:37 PM   #9
changing the tubes would easily add an hour to a plug change
johnsjmc is offline   Reply With Quote
Old 08-08-2016, 09:14 PM   #10
well don't you always change out the tubes when doing the spark plugs? i assume they go hand n hand.... thanks guys for thoughts.
Old 08-08-2016, 10:58 PM   #11
Steve Tinker's Avatar
The tubes only need replacing if the 2 x rubber O rings (located at the top and bottom of the tubes) are leaking. They can sometimes be difficult to remove and some have broken due to the plastic tube being brittle.
2001 MV Agusta F4.
Old 08-09-2016, 11:08 AM   #12
I was at 67K so I just had them replaced anyway. Also had cracks in my serpentine belt. Thanks for all your thoughts guys! very much appreicated.
