Old 08-03-2016, 07:34 PM   #1
LEJ
Passenger side radiator fan won't turn off
Got home from a short trip (3) miles. Radiator fan was working when I parked in my garage. Turned off the key and it was still running. About 1/2 hour later I returned to the garage and it was still running. Engine temp was normal during the drive.
Any help will be appreciated as to why it won't turn off. I had to disconnect the battery to keep it from discharging.
LEJ is offline   Reply With Quote
Old 08-03-2016, 07:58 PM   #2
HELP, cooling fan won't shut off!! - Rennlist Discussion Forums
I was just reading this post a few days ago. Might be helpful.
Chaiyz
2001 Boxster S
6 speed MT
chaiyz is offline   Reply With Quote
Old 08-03-2016, 09:29 PM   #3
LEJ
Thanks, some good info but since it's for a 944 not sure if it pertains to my 986
Old 08-04-2016, 06:36 AM   #4
LEJ
I'm thinking it's a bad relay. The Porsche/VW/Audi part number is 141951253B Later this morning, I'll head over to my local electronics supply house and buy 2, one for the high and one for the low fan settings. Hopefully that will solve the problem. They're only $7.99 ea so hopefully it may be a cheap fix. They are just a 4 prong relay available at most electronic shops
Old 08-04-2016, 07:42 AM   #5
Pull the relay and the fan should shut off. Then swap it out for the other side relay. If the fan stays shut off then i would say its the relay.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 08-04-2016, 09:15 AM   #6
LEJ .
I suggest you google this problem.Lots of tests and info to help you diagnose and repair.For Example:
http://986forum.com/forums/general-discussions/46404-one-my-rad-fans-has-stopped-working.html
Old 08-04-2016, 12:28 PM   #7
LEJ
The relays i purchased solved the problem
Old 08-05-2016, 10:24 PM   #8
Glad you got it working correctly Larry.
Cheers!
2001 Boxster S
6 speed MT
