Old 07-24-2016, 03:38 PM   #1
MFI Relay - Pin 85
Hopefully someone can help. I'm doing an engine swap (Audi 2.7t into Boxster S).
I've got the starter relay working fine but i'm struggling with the MFI relay. Pin 85 (red/brown) is shown as going through connector X59 pin 3 and into the DME (plug D pin 23).
Is it a switched ground controlled by the DME? Does the immobiliser have anything to do with it?
Escy is offline   Reply With Quote
Old 07-25-2016, 08:14 AM   #2
Yes, its a switched ground. The DME will not switch it until it has received the w-line signal from the immobilizer.
specboxCO is offline   Reply With Quote
Old 07-26-2016, 02:48 AM   #3
Thanks, sorted now.
