-   -   Coil pack replacement Part Number???? (http://986forum.com/forums/performance-technical-chat/62247-coil-pack-replacement-part-number.html)
kk2002s 07-06-2016 08:04 AM
Incredible how many different part numbers I'm seeing for MY 2002 S.
My current number is Beru 996 602 102 00 Beru# 0 040 100 021
Pelican shows a few (Some being "New Larger version")
996 602 101 01 - Smaller body
997 602 107 02 - Larger Body
Beru Site:
996 602 104 00
997 602 104 00
Has anyone recently replaced and what part number did you have success with??
Story: Replaced AOS a couple months back, on the test drive Flashing CEL with P0300, P0301 ++.CEL. Stopped car CEL went out Cleared codes.
Last week 700 mile road trip, Got the Flashing CEL with P0300, P0301 ++, Again light went out no issues
Pulled Right side bank coil packs and low and behold - 2 of 3 cracked. I'm just replacing all 6 but what part number works????
And Searching everywhere, I couldn't find any real definitive answer
LEJ 07-06-2016 08:57 AM
I'd suggest you call Pelican and ask one of the salesman. They are VERY knowledgeable and will steer you in the right direction.
JayG 07-06-2016 09:13 AM
Use the newer ones with the "larger body"
they should come with the longer bolts
Check out the pricing from warehouse33auto.com.
If you put rennlist in the promo/code box at checkout, you get an additional 10% off
Their service is 2nd to none
Gelbster 07-06-2016 03:57 PM
This may help you although not the exact same car.Good parts number info.:
Notes on coil pack replacement with new style coils - 6SpeedOnline - Porsche Forum and Luxury Car Resource
kk2002s 07-07-2016 10:13 AM
Gelbster and all, thanks for get back
This is what I was afraid of. I only checked right side coils and I didn't see any thing that would prevent using thicker body coils
I need to look at Left side to see if this pipe is there on Boxster. I now remember 1 coil being blocked from easy access
LEJ 07-07-2016 12:05 PM
I have a 2001 "S" and yesterday I changed all (6) spark plugs. I had sufficient room to use the thicker coil packs if needed. In regard to the new coils use of a torx bolt that requires an E10 female torx socket. It's simple enough to go the a specialty hardware store and get cap bolts with a 7mm allen head
newBgeek 07-07-2016 07:59 PM
I just change my coil packs, plugs, and tubes. I can vouch for having enough clearance for the bigger coils. There are no obstructions. That 996 thread doesn't apply to us. There was one bolt that you couldn't get a ratchet on, but that was the same for old coil. I just used my socket wrapped in some rubber from a nitrile glove and a small vice grip and that did the trick.
http://986forum.com/forums/uploads02...1467946602.jpg
http://986forum.com/forums/uploads02...1467946624.jpg
clickman 07-14-2016 07:25 AM
What are the improvements to the coils since the 9x6 came out of the factory? Why thicker? Ie why not just go with the original style?
kk2002s 07-15-2016 04:51 AM
I had only pulled one bank and 2 of 3 were cracked
One had a crack into the body but both had cracking around the bolt hole sections
So the thicker design, I think, would be less prone to that. Otherwise I don't know if there is something electronic going on with the thicker
Also It appears a regular 8mm socket will work on these Torx bolts
Even though the plugs I pulled looked excellent after 25000 miles, while I'm in there made sense to replace them.
