Old 07-01-2016, 05:13 AM   #1
18' Porsche 911 (1993-1998) on a 2001 Boxster S
Anyone fitted 18' Porsche 911 (1993-1998) on a 2001 Boxster S?
Advise on if this is possible? And required space please?
Thanks,
Joel 07788722352
swissjoel2 is offline   Reply With Quote
Old 07-01-2016, 06:04 AM   #2
Luv2Box's Avatar
I put 993 wide body turbo twists on my '99 which has a 2001 S rear suspension due to having installed 2001 S big red brakes and didn't need spacers. They're 8.5" in front and 10" rear.
Luv2Box is offline   Reply With Quote
Old 07-01-2016, 06:31 AM   #3
geraintthomas's Avatar
18" 987 Boxster S alloys on my 986 Boxster S. Car's standard - no spacers, standard suspension.
Sorry for the photo bombing
Porsche Boxster S Type 986
Old 07-01-2016, 09:04 AM   #4
BIGJake111's Avatar
Turbo twists were a factory option for the S, my car has them. It's a different part number then the 993 wheels. But turbo twists fit for sure. If you'll need spacers or anything if your car came 17 or not, I don't know.
Old 07-01-2016, 09:40 AM   #5
You don't need spacers, even if the car came with 17's. Mine did and it's fine.
Old 07-01-2016, 10:18 AM   #6
78F350's Avatar
What size are your wheels and offset Gerain? There are lots of different sizes of 18" Porsche wheels out there. I think the ones the OP is referring to are these (Early 996):
My rear Boxster (Victor Equipment Aftermarket) 18s are 9x18 ET49
These wheels are an inch wider. (Front side of wheels aligned)
I have read that they are best with an 18mm spacer (correcting to the prescribed Boxster off-set of 47mm for the 10x18s). From what I have read, the fronts are good.
I'm no expert, but I have a few wheels laying around and Google. Really need the full description of Joel's wheels to be sure.
Old 07-01-2016, 10:35 AM   #7
Very good point, for some reason I assumed that all 996 and 986 18's were the same offset! I stand corrected
Old 07-01-2016, 04:00 PM   #8
Photos of my rear wheels
Thanks for all your help guys. Attached are photos showing all the marking.
What does the H2 of 10Jx18H2 mean?
When I held them in position it looked like a 30mm spacer? This pushed it out of the wheel arch.
Please advise, nice cars by the way.
Old 07-01-2016, 05:09 PM   #9
78F350's Avatar
That looks like an 18" wheel 10" wide, with a 47mm offset. Hard to see the offset for sure.
Here's a chart from a wheel vendor that has that size (No spacer):
Porsche Wheel Fitting Chart and Fitment Guide | Alloy Wheels Direct
Old 07-01-2016, 05:17 PM   #10
78F350's Avatar
Here's a good guide about how to read wheel size markings:
Wheel Markings
Old 07-02-2016, 12:54 AM   #11
Et 47
Its says ET 47. When I offered the rims up to the car - they stuck out of the arch when giving enough clearance. Can you confirm these are incorrect please?
Old 07-02-2016, 07:27 AM   #12
BruceH's Avatar
This might help you, if they are ET 47, they should fit since stock is ET 50 and that is pretty close. My rear 18's are ET 65 from a 911. I had to get spacers for the rear.
Would these wheels fit??
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 07-02-2016, 11:54 AM   #13
So, itīs possible to use 993 turbo hollow spoke rims on a Boxster S -04?
Robert993TT is offline   Reply With Quote
