Old 06-29-2016, 06:37 AM   #1
jpc763's Avatar
75K Maintenance - What else do I need to do?
I am planning on doing a 75k mile check on the car. Based on documentation, it is just a oil change, air filter change and inspections. I know that the spark plugs were not replaced at 60k so I am going to do that too, along with the tubes.
What else should I consider doing? I have had the car 1.5 years and brought it to the Indy for a clutch, ims, rms and coolant reservoir. Another service for brakes. I did the oil change at the end of last year. Car runs well.
Oil & Filter
Air Filter
Cabin Air Filter
Spark Plugs
Spark Plug Tubes
Thanks, John
2001 Boxster S - Midnight Blue Metalic
jpc763 is offline   Reply With Quote
Old 06-29-2016, 07:41 AM   #2
There Is No Substitute.
rick3000's Avatar
It looks like you have everything covered, brake fluid, filters, etc. If it's not in the service records, I would change the fuel filter and change, or at least check, the serpentine belt.
