Old 06-13-2016, 02:04 PM   #41
Engine Surgeon
Originally Posted by Roger1965 View Post
No I'm not sure they are out that far. I am going off numbers provided by the previous shop I used, which I have stopped going to. I am sure they did not follow the correct warm up procedure.
But I do have about a half second of chain rattle on cold start which means I should probably look at the chain pads.
Thats a symptom of tired tensioners.
US Patent 8,992,089 &
US Patent 9,416,697
Old 06-15-2016, 05:10 AM   #42
+1 on the tensioners. I had a brief rattle on startup. Changed out all three tensioners. Problem solved. One of the tensioners was very weak.
FYI, I can't remember the specifics, but there was an upgrade to the tensioners at some point, so make sure you do your research when you shop for the parts.
Need_for_speed is offline   Reply With Quote
