Old 05-31-2016, 06:10 AM   #1
5.6 amps
Ok. Battery issues.
Pulled all fuses and the car is still pulling 5.6 amps.
Any idea what pulls this kind of amps?
99' base
G
GaryMulcahey is offline   Reply With Quote
Old 05-31-2016, 09:35 AM   #2
Do you have any aftermarket accessories installed? Aftermarket Radio, radar detector or alarm system could all be culprits.
Old 05-31-2016, 12:29 PM   #3
That is 5.6 times the max draw with switch shut off.
Any fans still running? Ignition switch? Corrosion on some ground?
Old 05-31-2016, 07:12 PM   #4
Yes, pulled the radio and that wasn't it. The car only has 40,000 miles on it.
Nothing aftermarket except the radio. No codes.
Checked for noise with the key out and nothing we could hear. Will give that a go again this week to make sure. And we will definitely pull the ignition switch.
So later this week it will be time to pull the alternator. Maybe a bad regulator.
Thanks for the help and suggestions
G
1999 Silver Boxster
www.mulcahey.com
https://www.instagram.com/garymulcahey/
Old 05-31-2016, 08:53 PM   #5
Track rat
Topless's Avatar
Originally Posted by GaryMulcahey View Post
Ok. Battery issues.
99' base
G
Lots of stuff. Ign, wipers, tail lights, brake lights, frunk lights, starter relay... Get out a meter and trace the circuits one by one. Process of elimination.
Strong Electrical drain problem! 1999 Porsche Boxster
Old 06-01-2016, 09:39 AM   #6
If you have pulled all the fuses, the options get small quickly. I would suspect stuck starter solenoid. as that comes directly from the fusible link panel, rather than through the fuse box.
specboxCO is offline   Reply With Quote
Old 06-01-2016, 02:43 PM   #7
1999 base
Meir's Avatar
Make sure you also pulled the fuses located in the trunk.
Old 06-01-2016, 03:01 PM   #8
Yup - only one back there, for the Secondary Air Injection pump. Pull it and check, could be the culprit.
Old 06-01-2016, 07:28 PM   #9
Ahhh. Ok.
Didn't know that. Will look in the trunk. Thanks Lads.
1999 Silver Boxster
www.mulcahey.com
