Old 05-21-2016, 03:10 PM   #1
geraintthomas's Avatar
Question Rear clunking. Is it this?
I know, I know, there's lots of threads about this and I'm aware of that. I just like to ask a question. I have a clunking from both sides on the rear, as if both sides have a part that's loose or worn out. Over rough roads I can hear it, not so much on motorway speeds (if at all).
I'm guessing it's probably the upper control arms.
I know it's very hard to diagnose these, so that's fine. But I'd like to rule out everything else before forking out a lot of money on two new arms.
So from looking at this photo, I'd like to ask for some help:
- The upper control arms are probably the culprit, but I've noticed the lower control arms and toe arms; would these knock at all? Or is it very unlikely?
- It COULD be drop links, but how do I check the condition of the drop links, in case these are the culprit?
Thanks for the help I just want to make sure I can check everything I can before buying two new arms.
Porsche Boxster S Type 986
Old 05-21-2016, 06:59 PM   #2
oldskool73's Avatar
Replacing part #8 with new TRW parts fixed clunking over bumps at low speeds for me.
oldskool73 is offline   Reply With Quote
Old 05-21-2016, 08:49 PM   #3
Racer Boy
Racer Boy's Avatar
It's probably #8, if that doesn't fix it the it's the drop links.
Old 05-22-2016, 01:45 AM   #4
I know this but my question was how I'd go about testing the drop links, and lower control & toe arms if they would knock. Like I said I'm not going to buy the upper control arms before testing the other parts first as they're expensive.
I'd just like to know how I'd go about testing those parts
Old 05-22-2016, 05:05 AM   #5
Artist, 986S tinkerer
NewArt's Avatar
You could unbolt a drop link and inspect the state of the rubber bushings. Easy to do but, of course inconclusive. Inspect bushings for dryness and cracks.
Old 05-22-2016, 06:38 AM   #6
steved0x's Avatar
I guess you could unbolt the lower drop link from the sway bar and go for a ride and see if it solves it?
Old 05-22-2016, 09:16 AM   #7
Racer Boy
Racer Boy's Avatar
There's no way to "test" the parts. I just replaced every part but the rear toe-link in my 2002 base Boxster, and the parts all felt fine if you moved them around by hand, but the suspension was clunking, squeaking, and groaning a ridiculous amount. With new parts, no more suspension noise.
The lower control arms are unlikely to be making clunking noises, they usually squeak or groan.
How many miles on your car? Superior Porsche engineering ensures that most of the parts wear out prematurely at around the same time, although #8 seems to wear out prematurely first.
Old 05-22-2016, 02:44 PM   #8
Thanks for the help guys, much appreciated there looks like I'll be replacing the upper control arms then!
The car's done 88,000 miles. There's no squeaks, groans, nothing. The interior doesn't rattle, there's absolutely no sound at all. It sounds like a luxury saloon on the motorway. The only noise is the damn knocking at the rear left and right on bumps.
I'll buy new control arms next week the only two things that are wrong with the car are these knocking parts, and a split CV boot. Both of which I'll fix next week and the car's spot on mechanically
Old 05-22-2016, 08:34 PM   #9
Froggo's Avatar
Hi There , first post , I had the same problem , I removed the track arms and the rubber gaiters around the ball joint . Then squirted in as much lithium grease as it would take , result -- no more knocking so far !! Somewhat cheaper than new ones and worth a try.
2000 Triple Black Boxster S
2017 Subaru Outback Grey
Froggo is offline   Reply With Quote
Old 05-23-2016, 12:45 AM   #10
Very interesting. I wonder if that is worth a try...
Old 05-23-2016, 05:47 AM   #11
Racer Boy
Racer Boy's Avatar
If you're going to the trouble of pulling the trailing arm out, you may as well as put a new one back in. The lithium grease is a short-term fix; the arm clunks because the spherical bearing is worn out.
Old 05-23-2016, 06:02 AM   #12
Gotcha.
I've heard the suspension needs to be under load when changing this. Could this be done by jacking up the brake disc before removing it?
Old 05-23-2016, 10:34 AM   #13
The best way to remove/replace this arm is to put the back of the boxster on jack stands so the rear is not under load and then take your floor jack and a block of wood and jack up the hub to the point that you can easily remove the arm. It's not the easiest part to remove and replace as it's in there tight on both ends, but it's doable.
Anticipate cursing, extra beers, and probably one or two cuts on your knuckles from this procedure.
Old 05-23-2016, 10:52 AM   #14
Originally Posted by [B
Anticipate cursing, extra beers, and probably one or two cuts on your knuckles from this procedure[/B].
Good advise...
Old 05-23-2016, 11:03 AM   #15
steved0x's Avatar
If you have ramps you can back up onto the ramps and perform the job right from there. Here are some pics: Rear trailing arms replacement guide DIY
Old 05-23-2016, 01:56 PM   #16
911monty's Avatar
What I did and made it the easiest work I have done yet is, 1. Back up on ramps. 2. Jack wheel off ramp. 3. Turn ramps around (backward). 4. lower tire back on ramps. With ramps in backward you have full access to the control arm without ramp in the way. Remove bolt on front of control arm. Remove rear bolt on coffin arm. Slide arm out. Place new arm in position and start bolt in coffin arm (do not tighten) install front bolt and tighten. Now tighten coffin arm bolt, (this keeps bushing in neutral state). Repeat other side. Now turn ramps around and drive off. Took less than 20 min per side.
Old 05-23-2016, 02:56 PM   #17
Good tip
Old 05-24-2016, 02:58 PM   #18
Racer Boy
Racer Boy's Avatar
That is the way to do it! The ramps are in the way, so reversing them solves that problem.
Old 05-24-2016, 03:04 PM   #19
Just need to get some ramps now heh!
Old 05-25-2016, 09:58 AM   #20
I have a clank over low speed bumps coming from the back. I got under there last time I had the car on jack stands and whacked everything with a rubber mallet, my thought being that thud = good and clank = bad.
The only things that clanked were the drop links, so I'll change those first and see if that fixes it. Probably be doing it in the next week or so, along with the sway bar bushings. I'll post my results.
'99 black 986
