Old 04-27-2016, 05:12 PM   #1
binkoba's Avatar
Litronic Headlight Issue, One Side out
2003 Boxster S
I had passenger side Headlight out.
I bought new pair of ZEON lights
Installed both
Passenger side still out
Swapped sides, new Zeons
Reinstalled both old Zeons
Swapped Sides
Switched Lights switched off and on many times
Banged on Light switch
Any Ideas what next?
Thanks for you time.
Ashley
2003 Boxster S
binkoba is offline   Reply With Quote
Old 04-27-2016, 07:05 PM   #2
KevinH1990's Avatar
Look at this post: http://986forum.com/forums/general-discussions/60607-trouble-xenon-headlight.html
It has information on the trouble shooting process. The next step I would try in your situation is to swap the ballast from one unit to the other. (The ballast is the large metal box at the back of the headlight. It provides the high voltage current needed to excite the molecules in the Xenon gas to the level where they emit light.)
It is easy to remove the ballast. Just remove the fasteners and wiggle off the electrical connectors. I bought a used ballast on eBay when I had one go bad.
Here's a link to a post on my adventure with litronics: http://986forum.com/forums/general-discussions/54697-advice-used-litronics.html
I had a bad ballast and problems with the wiring to sort out. Some board members had to replace the light switch.
Good luck.
Old 04-27-2016, 10:22 PM   #3
check if the blue connector is OK. Sometimes they get broken. Sorry, did the chart in german language only.
In general i would say it's a connector problem, but it also can be a ballast problem.
Regards, Markus
Old 04-28-2016, 06:11 AM   #4
binkoba's Avatar
Thanks very much I will check it out this weekend
Ashley
Ashley
2003 Boxster S
Old 04-29-2016, 07:48 PM   #5
Also want to inspect the internal wiring of your headlight assembly. The insulation is prone to drying out and cracking. causing short circuits to specific bulbs within the assembly.
dghii is online now   Reply With Quote
Tags
headlights , litronic
