Old 04-27-2016, 06:05 PM   #2
KevinH1990
KevinH1990's Avatar
Look at this post: http://986forum.com/forums/general-discussions/60607-trouble-xenon-headlight.html
It has information on the trouble shooting process. The next step I would try in your situation is to swap the ballast from one unit to the other. (The ballast is the large metal box at the back of the headlight. It provides the high voltage current needed to excite the molecules in the Xenon gas to the level where they emit light.)
It is easy to remove the ballast. Just remove the fasteners and wiggle off the electrical connectors. I bought a used ballast on eBay when I had one go bad.
Here's a link to a post on my adventure with litronics: http://986forum.com/forums/general-discussions/54697-advice-used-litronics.html
I had a bad ballast and problems with the wiring to sort out. Some board members had to replace the light switch.
Good luck.
KevinH1990 is offline   Reply With Quote
