04-20-2016, 04:47 AM
01101
Misfire, no codes
Drove to Boston the other night from CT (2hrs each way)
On the way there, holding 70-75, slight uphill, light throttle, and intermittently - the car would skip occasionally, felt like a hard jolt. More throttle would smooth it out.
Filled up in Boston with 93.
On the way back it was doing the same thing, intermittently. Seemed to be getting a little worse. At about mile 100 from the fillup (5min from home) it went into full random misfire and brought on a flashing CEL. Took it out of gear, revved it to 5 or 6k and it cleared up. Finished the drive home with nothing more than the random skip.
Brought it to pepboys for a free scan on my way home from work yesterday - no stored codes.
Had a friend bring over his Innova 3150 scanner, no stored codes.
Will a durametric be able to show me what's happening? Anyone have any ideas?
04-20-2016, 05:33 AM
Artist, 986S tinkerer
A Durametric might give you more info. You might check your coil packs for cracks. Good plugs and good connections?
04-20-2016, 06:21 AM
01101
Plugs have 653 miles on them. Some of the coils may have had cracks back when I was replacing plugs. I don't want to go and get a whole set of coils unless I can prove that's the issue, or narrow it down to 1.
04-20-2016, 08:22 AM
Was it rainy or humid that day? If yes, check the coil packs and do a visual inspection of the coil pacs.
If they have cracks that doesn't mean that they are bad. Mine had cracks but they worked. Replaced them all precautionary and sold the crack fee ones on ebay.
Did you check the spark plug electrode distance when installing the plugs? Are the spark wires 100% connected?
What tool did the workshop use to read the codes? Porsche specific or generic OBD2?
Regards, Markus
04-20-2016, 08:50 AM
01101
Regards, Markus
Its been dry here for weeks. I checked all gaps as I was installing the plugs. Connections seemed solid, and car ran 100% up until this trip.
Tools are both generic OBD2. Anyone have a durametric near central CT?
I have a VCDS, so I'm going to try that tonight.
04-20-2016, 09:16 AM
Did the tach act weird when misfiring? Perhaps CPS getting weak?
04-20-2016, 09:33 AM
01101
Nope, tach holds steady.
04-20-2016, 09:58 AM
Cleaning the MAF is pretty simple and inexpensive. I'd try that before throwing new parts at it if a Durametric isn't handy.
04-20-2016, 11:30 AM
01101
I'll give this a shot.
04-22-2016, 05:06 AM
01101
I got my VCDS cable back from a friend and hooked it up. Still no codes.
But now I can have a passenger sit with the laptop and monitor timing/MAF/throttle/load/etc...
04-27-2016, 05:35 AM
01101
Attempted to drive it to work this morning, but started misfiring badly.
I drove it home, and kept it running - grabbed vagcom and scanned it quick
Wednesday,27,April,2016,08:02:52:42003
VCDS Release 15.7.4 (x64): Generic OBD2
Mode 07: Pending emission related fault codes
Address 11 (Engine): 3 Faults Found:
P0300 - Random/Multiple Cylinder Misfire Detected
P0306 - Cylinder 6: Misfire Detected
P0302 - Cylinder 2: Misfire Detected
04-27-2016, 09:09 AM
so i would say change the coil packs from 6 to 5 and 2 to 1 and see if the error moves along with the changed coil packs. Then you know it's the coil packs and which one it is.
Else you could also clean the MAF, but that seems to be the coil packs, sparks or wires or connectors.
Regards, Markus
04-27-2016, 09:47 AM
01101
Regards, Markus
I think that will be my plan, but if I'm going under there, I may just swap in new coils anyway. at 98k miles, it could probably use them anyway.
The part number on my coils is 996 602 102 00
Does it make sense to use the same ones, or the updated 99760210700?
04-27-2016, 04:25 PM
01101
Disconnected the MAF, just to rule it out, and drove around. Still misfiring.
Painfully loud with the intake and no engine cover at WOT.
04-28-2016, 04:59 AM
01101
Thanks for the info, and the help!
05-02-2016, 06:30 PM
01101
I swapped the #5 and #6 coils, still misfiring, but it wouldn't throw a code on a short drive. I'll try again tomorrow.
I pulled the #5 and #6 plugs just to have a look.
05-02-2016, 07:25 PM
Could be lighting but I'd say the plug on the right is running extremely lean.... that insulator appears to be scary white appears to be getting too hot to me.
05-03-2016, 04:46 AM
01101
I agree with you there. I thought the tip looked odd when I pulled it out, so I took #5 out to compare - and it is definitely lighter. If that is the case, I would imagine the misfire is more fuel related, rather than ignition.
It's a bit frustrating have the motor skip, and not throw a code. I have to drive it more to cause a stumble so I can rule out the coilpacks.
05-03-2016, 08:18 AM
Hello alm001,
i agree, this looks more like a fuel injector problem.
So i have some questions:
When did you clean the sparks the last time? / How many miles ago?
is your car a daily driver or a seasonal car or did it sit for a longer time in the past?
If is had sit for a longer time, did you use a fuel stabilizer before you got it to sleep?
Did you use an injection cleaner in the near past?
Was the engine really warmed up before you pulled the sparks? Because they should look a bit more brownish.
Thanks & regards,
Markus
