Old 04-18-2016, 06:10 PM   #1
Anyone running with a metal impeller water pump?
Finally got some nice spring weather and been re-acquainting myself with my 01s.
Im going to put it up on the lift soon and do a bunch of maintenance of on it.
The current water pump is at least 7 yrs old and has between 40 and 80K miles on it.
A few years ago, I was planning on doing the water pump and never got around to it. I bought a metal impeller Pierburg brand water pump at the time.
It's been sitting on the shelf in my garage since. Now there is Internet hysteria (?!) about catastrophic failures of metal impeller pumps.
I am trying to figure out if I should put this one in, or forkout money for a different plastic impeller water pump.
Peter
Sent from my LG-D852 using Tapatalk
petee_c is offline   Reply With Quote
Old 04-18-2016, 06:28 PM   #2
steved0x's Avatar
My pierburg had a composite impellor, is there a chance it is just dark gray composite and looked metal? Post a photo if it is handy.
Old 04-18-2016, 06:52 PM   #3
I will take it out of the box and take a look. Thx
Old 04-18-2016, 06:31 PM   #4
Artist, 986S tinkerer
NewArt's Avatar
Really Peter, you should read the sh**load of posts on this forum about this. Search metal impeller.
Enough can already go wrong without gambling.
Old 04-19-2016, 07:47 PM   #5
Well, I've been on here on and off since 2007,and bought my car in 2009.
I did search about the different types of water pumps, and thought I had bought a metal impeller version back in 2011/12.
Turns out I didn't.
That being said, I did inquire about the life of a metal impeller pump and was going to base my decision on whether I used one on how much useful life I thought I could get out of it. Say if I had a sample size of 10-20 real posters here on 986forum, rennlist.com, or renntech or pedrosboard.com that said they got XX, 000 miles out of their pump before they replaced it, then I might consider putting it in for 60% of that life if I could get 2-3 yrs out of it.
Or if I had 2-3 people that said they got YY, 000 miles out of their pump before failure, I might go with 40% of that number again if it lasts me 2-3 yrs of projected driving life.
I didn't find either of those numbers.
I don't mind wrenching on the car. The roads around here are boring, straight although being rural, there is plenty of opportunity to wind it up a bit as the police presence is scarce. However, I've got 2 young kids and 1 wife, and only 1 passenger seat, so if I'm wrenching at least I'm at home with them and spending quality time with the boxster.
My car is a fair weather car only from April to early November.
I'm not rich enough to just throw out a part willy nilly without trying to figure out if I can get some life out of it. I guess I could have put it up on eBay and recouped some money that way.
These cars have been around for almost 20 yrs now. There really isn't a whole lot new to discuss. This is the same with all 986 related boards. The trends repeat themselves over and over.
The typical life span of a water pump still is an unanswered question in my research. I believe porsche intended it to be a lifetime part according to their maintenance schedule. We are now away from that view.
My current pump might be original, and might be 15yrs old with 124,000km on it. Never topped up the coolant in the past 7yrs. It's coming out this spring and I'm going to put in this brown composite impeller pump in. No idea how long this current pump will last, all my other vehicles have had timing belts and the pumps got replaced before failure when I replace the TBs at around 120,000km.
Peter
PS. I don't mind a good oil discussion.
Sent from my SM-T700 using Tapatalk
Old 04-20-2016, 05:55 AM   #6
steved0x's Avatar
I can give a data point - I replaced my water pump proactively (there was nothing that appeared to be wrong with it and no leaks) in January 2015 at 115,000 miles (car is a 2000 so 15 years old). It turned out to be the original WP still, and it wasn't wobbly but the bearing was rough when I spun the WP by hand. The new one was silky smooth.
Jake Raby recommends replacing every 3 years regardless of mileage in this rennlist thread (kind of old so he may have updated his guidance since then)
Old 04-18-2016, 06:41 PM   #7
There Is No Substitute.
rick3000's Avatar
A genuine Pierburg WP should not have a metal impeller, the impeller should be dark grey plastic.
Old 04-18-2016, 06:47 PM   #8
Jesus christ not again. SEARCH.
And please...don't ask about oil next.
Old 04-19-2016, 01:17 PM   #9
Giller's Avatar
Wow, some of you guys are brutal! Maybe you would be more at home over at Rennlist??
Old 04-19-2016, 04:40 PM   #10
Getting the same threads within a week of each other, almost to the letter, is brutal. It's common forum etiquette on every forum I've ever partaken in. Use the search function first. If you think I'm brutal you need to get some calluses.
Old 04-19-2016, 06:12 PM   #11
Giller's Avatar
You're the one swearing away and you are going to lecture on forum etiquette? And if you are all concerned with getting some calluses, maybe you should take your own advice and grow a calluse about all these same threads.
Old 04-19-2016, 06:37 PM   #12
Swearing away? If what I've said offends you, you should really stay off the Internet. Or for that matter don't leave your home.
Old 04-18-2016, 07:50 PM   #13
OK. Is this metal or composite. It's a brown color impeller.
Unsealed the box tonight.
Old 04-18-2016, 08:37 PM   #14
"50 Years of 550 Spyder"
10/10ths's Avatar
Get a battery....
.....hook up a positive wire and a negative wire.......
Old 04-19-2016, 10:35 AM   #15
lkchris's Avatar
Do you have a magnet?
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 04-18-2016, 08:45 PM   #16
You mean test the resistance?
Old 04-18-2016, 10:37 PM   #17
Steve Tinker's Avatar
That looks like a composite impeller - to be sure just check its resistance with a multimeter. If its the same resistance as touching the multimeter prongs together, its metal.
2001 MV Agusta F4.
Old 04-19-2016, 02:26 AM   #18
Pierburg has always a composite impellers. And this one is also cheap plastic. So wouldn't fit for me.
Regards, Markus
Old 04-19-2016, 04:51 AM   #19
steved0x's Avatar
Looks like composite to me, you should be good to go!
Old 04-19-2016, 07:27 AM   #20
Great news. My memory was a little foggy. This pump has been sitting on the shelf for maybe 4 yrs.
Yeah, I procrastinate.
