Old 04-17-2016, 11:55 AM   #1
Simple Battery Buddy Question!
This may be a silly question but my battery died and I have one of those NOCO genius chargers. Do I connect both the black AND Red clips or just the black one to the battery to charge this sucker?
Lexicon is offline   Reply With Quote
Old 04-17-2016, 12:06 PM   #2
Not familiar with this brand, but you have a positive and a negative on your battery...so I'd assume you'd need to connect both positive and negative terminals. Otherwise your battery won't charge.
Old 04-17-2016, 03:26 PM   #3
pjq
Positive wire connects to battery positive post and negative wire connect to a good ground point on your car. Then plug the charger in and turn it on.
Old 04-17-2016, 06:05 PM   #4
Artist, 986S tinkerer
NewArt's Avatar
Just to clarify: the negative terminal of your battery is connected to "a good ground point". Modern sealed batteries are less likely to give off explosive gasses than the old style open cell batteries. You can connect the black wire to the negative battery post or any good ground point on your car.
Old 04-18-2016, 08:42 AM   #5
Smart choice:
Car Battery Chargers Top 10 Under $100 For 2015
But some better/more $ ideas here:
http://986forum.com/forums/general-discussions/56011-battery-maintainer-question.html
