Old 04-12-2016, 05:03 AM   #1
PaulDash's Avatar
Shifter play at transmission [Video Inside]
This topic has been covered before, but here's a fresh question...
I greased the shifter cables, which helped with shifting smoothness.
I replaced my eBay short-shifter with a 997 shifter, which helped some more and reduced shifting effort (although it did lengthen the throw noticeably).
I still get some shifter play. It seems to be at the transmission, as illustrated here: https://youtu.be/4Kt2JPdsIZo
What can I tighten, fix, replace to remove the slop?
Past: 944 NA white '86
Present: 986 black '98
Future: 959
Last edited by PaulDash; 04-13-2016 at 02:29 AM. Reason: To get some answers by bumping the thread higher in the forum.
PaulDash is offline   Reply With Quote
Old 04-13-2016, 03:32 AM   #2
Project Addicted
jcslocum's Avatar
Paul,
Looks like the right hand shift cable end or the pin it connects to is worn or loose. I fixed something similar on our Box when i had extra slop found when the trans was out.
Here is a recent discussion and fixes done:
http://986forum.com/forums/general-discussions/60643-excessive-shifter-play.html
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
