Old 03-22-2016, 05:33 PM   #1
JGriff
JGriff's Avatar
Rear Brake Grinding
I was having an issue with the driver's side rear caliper making a real bad grinding noise. When I took out the pads, I found out that one of the vibration dampers had stuck to one of the pads.
I got the pads out...and ultimately put in new pads and dampers. But the noise is still there! The rotor is scored quite badly...could that be the problem? Should I replace the rotor? Take a look:
Sent from my SM-N900V using Tapatalk
JGriff is offline   Reply With Quote
