Old 03-22-2016, 06:04 PM   #2
JayG
On the slippery slope
JayG's Avatar
No, its just fine. Rotors are not supposed to be smooth on the surface
Uh YES!! You need to replace the rotor.
That looks like it was grinding for more than a few miles. How long have they been grinding
I'll bet the pad was down to the metal backing plate.
I hope you replaced all the pads on that axle, not just the one wheel
You may need to replace the pads again as they will be worn to match the scored rotor
Look on ebay for Meyle rotors and you can find them for $75-$85 a pair. I would replace both of them and check the other axle to see if it has the "lip" on the edge like your rears look like they have. The rotors have only a 2mm wear from new to worn out
The dampers will be stuck to the pad, use a small putty knife to separate it from the pad and you can reuse them if you are even slightly careful.
If your brake fluid has not been changed in the last 2 years, you need to do a flush, replace, and bleed
at very least, bleed the brakes
BTW, it's always nice to introduce yourself on your first post
And without pics, it ain't real
2004 996 Targa Tip
Instructor - San Diego region
