Old 03-18-2016, 07:11 PM   #1
1998 Boxster Owner
Rough idle/no rev problem
I'm going to move this problem to the technical forum. I have a '98 Boxster Base with a rough idle/no rev problem. The battery and plugs are new. The coil packs ohm out. The fuel pump and fuel filter are new. Fuel pressure is rock solid. The vacuum looks to be good. Oil has been changed as well. Could a stuck fuel injector or injectors cause the rough idle and inability to rev about 300 rpm?
tada is offline   Reply With Quote
Old 03-18-2016, 11:08 PM   #2
Oggie's Avatar
I'd check your MAF. I had similar symptoms and it turned out my MAF had failed.
'99 base Boxster (Arena Red Metallic/Savanna Beige)
'02 911 Carerra Cabriolet (Arctic Silver/Metropole Blue)
Oggie is offline   Reply With Quote
Old 03-19-2016, 07:18 AM   #3
I second the maf. If you disconnect the maf sensor the engine should then run in open loop. If it runs better it is a sure sign the maf is bad. Sometimes cleaning them helps but not always and be sure to use a cleaner spray designed for maf cleaning
johnsjmc is offline   Reply With Quote
Old 03-19-2016, 12:38 PM   #4
1998 Boxster Owner
Disconnecting the MAF made no difference. I am definitely missing on cylinders. Trying to get access to ohm out the injectors. From underneath it's tricky. May have to remove the secondary air pump on the passenger side and the air box on the drivers side to get full access to the injectors and rail.
Old 03-19-2016, 01:37 PM   #5
A major vacuum leak would cause this. Are you getting any codes?
Old 03-19-2016, 01:48 PM   #6
1998 Boxster Owner
No codes at all. No CEL as well
Old 03-19-2016, 02:56 PM   #7
1998 Boxster Owner
Does anyone know the proper resistance for the injectors? I got to one and measured 12.2 ohms. I also measured the voltage at the injector connector to be 12 volts with just the key on.
Old 03-20-2016, 04:58 AM   #8
Have you checked for vacuum leaks? I had this happen after doing some work on the intake. Put it back together and couldn't see it from the top, but I had created a vacuum leak when I put it back together wrong. No codes because it wouldn't stay running. If you aren't getting any codes I highly doubt it's anything related to your injectors.
Old 03-20-2016, 07:31 AM   #9
1998 Boxster Owner
Thanks for the replies. I would really like to learn a way to check this vehicle for vacuum leaks. I have checked the vacuum lines on the drivers side that goes to the fuel regulator. I can see no leaks and fuel pressure changed when disconnecting the vacuum line. On the passenger side, I have traced from the intake manifold all the way to the vacuum canister and the four way tee. I can't see any damage to the lines so far. And I can't really do much other than visual inspection. Pin hole leaks would be almost impossible to detect visually. And I can only keep the car running about 15 seconds, so chasing a leak with something like carb cleaner won't work. Keeping it running long enough to troubleshoot is a problem. I'll post a video of it running to give you all a better idea of what I am seeing and hearing. I do appreciate all of your help.
Old 03-20-2016, 09:28 AM   #10
1998 Boxster Owner
Here's a video of its normal performance:
Boxster kind of running photo, picture, image on Use.com
Old 03-20-2016, 10:02 AM   #11
You can rent a smoke machine, make your own, or get it to a mechanic to figure out. This is the best way to check for vacuum leaks...with only being able to run for 15 seconds, it isn't a small leak or a pinhole issue if it is caused by a vacuum leak.
When was the last time the car ran right? What have you done to it that may require you to check your work? If you retrace those steps you may find the answer.
Old 03-20-2016, 10:24 AM   #12
1998 Boxster Owner
It never ran right, yet. In other threads in the General Discussion area I explained I bought a non runner and am trying to get it going.
Old 03-20-2016, 12:59 PM   #13
I haven't heard of these things having much of an issue with injectors. I'd look into a smoke machine to get that at least eliminated as a cause. After that I'm not sure where to lead you with no codes being posted.
Old 03-20-2016, 02:11 PM   #14
78F350's Avatar
Brake boost vacuum line? That's the biggest one and I'd think most likely to completely stall the engine. It mounts to the front left or right rear intake manifold and the opposing one should be covered/blocked.
Old 03-21-2016, 05:40 AM   #15
1998 Boxster Owner
I took a look this morning and found this, should it attach to something?
Old 04-21-2016, 06:43 PM   #16
Hi Tom,
to me that looks OK. Even there is a little deviation, the engine should run - and not in the way it runs on your video. Also the problem in general isn't a bent crank at this engines. Mostly it's a chain that sprung over – caused by a failed chain tensioner, broken chain ramp or anything related to ims mechanism.
Do you have any infos from the preowner how the car stopped working and what he or his workshop did to fix the problem?
From the symptoms i'm still on the clogged catalysator or intake side.
Regards, Markus
Old 04-21-2016, 06:56 PM   #17
1998 Boxster Owner
Hi Tom,
Regards, Markus
Hi Markus,
I'm just following ideas and eliminating variables. Below is what I bought to check the catalytic converters. Screws right into the O2 sensor holes. But, I'm running out of time tonight and I will save it for tomorrow.
As for the previous owner, he bought it in Glenwood Springs, Colorado at a used car lot in July 2015 for $8000 and had 94368 miles. Drove it to Sierra Vista, Arizona. Parked it. Would not start. He tried changing plugs. It was obvious his girlfriend (the actual owner on the title) had had enough of it. Their prospects were towing it to a Porsche dealer or Indy in Tucson, 100 miles away. So getting history from them was useless. They didn't know it had a toolkit (I needed the tow eye for the flatbed). I ran carfax and autocheck. 7 previous owners. Was a lease car for its first four years with 4 owners in those first four years.
Tom
P.S. Before this is all over, I think I will own every specialty test tool available. It would be great, but my other cars actually run dependably and need little maintenance. I guess I will be setup for servicing Porsches for life.
Old 03-20-2016, 02:16 PM   #18
Mine ran like that when I left the oil fill cap off. It creates a vac leak. Worth checking the cap and the fill tube.
spendy is offline   Reply With Quote
Old 03-20-2016, 02:41 PM   #19
Last two posts are good examples of why I'm saying try and track down a vacuum leak. The car will tolerate them for a bit but when they become too large it can no longer compensate and it shuts down.
Old 03-20-2016, 03:14 PM   #20
1998 Boxster Owner
Thank you all again for advice. I'm going to do some disassembly tomorrow and track down that leak. Took the day off and went down to Tubac, AZ (a small artists colony). Bought a couple of pots for my wife and had a great Mexican meal with my wife (the margaritas are hampering car repair). The goal is to have the car running by my 33rd anniversary at Memorial Day and drive it to San Diego.
