Thread
Rough idle/no rev problem
03-19-2016, 08:18 AM
3
johnsjmc
I second the maf. If you disconnect the maf sensor the engine should then run in open loop. If it runs better it is a sure sign the maf is bad. Sometimes cleaning them helps but not always and be sure to use a cleaner spray designed for maf cleaning
johnsjmc
Find More Posts by johnsjmc
