Old 02-10-2016, 11:47 AM   #1
M030 ROW springs on a base model strut?
I wanted to confirm that the M030 Struts are indeed shorter at the top. I thought I could just buy the M030 ROW springs and use them on my 2002 base bilstein struts and after installing it in my car the springs are just a tad too short when the car is in the air. I'm taking maybe 2 mm too short but still i dont want to risk it.
Alex
GatorLapis is offline   Reply With Quote
Old 02-10-2016, 11:54 AM   #2
can i just retread the rod all the way down?
Old 02-10-2016, 12:32 PM   #3
The springs wont fall out. They might rattle if you are air borne.(which should be never). I wouldn,t worry about it. The shafts are also hardened so you won,t be able to thread them any further.
johnsjmc is offline   Reply With Quote
Old 02-10-2016, 04:17 PM   #4
Luv2Box's Avatar
The ROW suspension does lower the car by a little less than an inch all the way around. Don't remember it in mms but maybe that is what you are seeing.
Luv2Box is offline   Reply With Quote
Old 02-10-2016, 05:13 PM   #5
the row springs are about 10-20 mm shorter and the corresponding shocks are also about 10 mm shorter. As I said above they won,t fall out even at full droop .Don,t worry about it
