Old 11-21-2015, 12:41 PM   #1
Oh lord, not another exhaust question
Yes folks, sorry, its a quicky. I just purchased the Circuit Werks secondary cat bypass pipes, and, while I was at it decided to also buy the exhaust system too .....the question revolves around clamps, should I reuse the stock clamps on the c-pipe, or, just take them off and go with the Torca EasySeal Clamps. If I went with the EasySeal, I assume 4 would be required (exhaust to c-pipe, c-pipe to test pipe X2)??
Regards,
Jake.
jpl2407 is offline   Reply With Quote
Old 11-21-2015, 05:27 PM   #2
Good move! I installed the Circuit Werks bypass pipes and Beluga Racing cat back - personally I reused the original clamps with no problems at all. If you use the easy clamps, you should only need two - headers to cat pipes is a different setup, should only need them for bypass pipes to cat back.
CraigM is offline   Reply With Quote
