Good move! I installed the Circuit Werks bypass pipes and Beluga Racing cat back - personally I reused the original clamps with no problems at all. If you use the easy clamps, you should only need two - headers to cat pipes is a different setup, should only need them for bypass pipes to cat back.
Reason: grammar
