Old 11-04-2015, 07:20 AM   #10
Originally Posted by boxster View Post
So, given that I am not planning on removing the engine from the car, LN's bearings without additional oil feeds is the best solution for my 99 spec car?
Also, as i stated before,I dont use the car much, and since statistically those are the type of cars that suffer the most,will LN's bearings have the same problems with cars that dont get used much? They say they life their bearings at 75000 miles or 6 years, since I don't use the car much, if after 6 years the bearings will have 20000 miles on them, will they still have to be changed?
first of all you'll need to make shure that the installation is 100% correct. If you don't have the tools, knowledge or know how i would say change your motor oil yearly with a high qualitiy oil, change and examine the filter and leave the bearing alone.
Additionally - if you have a double row bearing engine. The bearings of these engines don't fail that much as single row bearings. And there are a lot of others causes why theses engines can fail. So don't go crazy on thinking abount the bearing - that's my personal opinion.
Well, 6 years or 75k miles means 6 years or 75k miles. Perhaps Jake can answer this question. Also Jake should give you a recommendation which of his systems match best for your car.
Regards
Markus
