Old 10-01-2015, 02:10 PM   #1
The Gimp
Habby73's Avatar
Gas tank not venting w/o Evap System
Hi guys, so I've tried to do everything I could think of, but for about a year now it's been slow to fill my gas tank due to the pump shutting off. I know this means it's not venting properly. When it happened I took off the front wheel well cover and tried to figure it out, only to find a nasty Evap system in there, so I deleted it thinking it might fix the problem. The hoses from the tank are open ended in the wheel well now, and I removed the valve around the filler neck. Nothing has worked. I've even blown compressed air through the lines to the tank, and eventually with enough pressure it will vent, however it still won't fill normally.
Any help would be appreciated, thanks!
2001 986S
Habby73 is offline   Reply With Quote
