Old 09-30-2015, 03:13 PM   #1
Programmable Standalone ECU
Hey guys,
The bench flash I have on my 3.8 is great and all, but I want a programmable one. Any ideas?
I have a 1999 2.5L base Boxster with a 3.8 M96 motor.
99 Porsche Boxster 986 3.8
85 Toyota Corolla AE86 F20C
12 Honda Accord
16 Mercedes C450 AMG
22 Tesla Model X Plaid
Old 09-30-2015, 06:23 PM   #2
are you looking for something like Megasquirt..?
Old 09-30-2015, 07:31 PM   #3
This will sort of open up a can of worms for a street car. For starters, you'll have to figure out a way to pass emissions in AZ. There will need to be some integration with the rest of the chassis in order for everything to work correctly like it did before. Not that it can't be done, but it's something to consider. The fact that it's a 2.5 chassis makes things a lot easier than an earlier car because there is almost no CAN integration. If your car has cruise control, you would lose that feature, and you would have to do a few things to make the AC work correctly, but it's nothing I haven't done before. It honestly wouldn't be too difficult, just a bit of an investment to do it correctly. For what you need to do, an AEM Infinity 8 would get the job done. It's pretty good hardware for the money, and very capable.
Is this something you are wanting to tackle yourself, or would you be having a shop do the work?
If a plug and play solution is what you're looking for, there isn't one.
kcpaz is offline   Reply With Quote
Old 10-01-2015, 10:21 AM   #4
Passing emissions in AZ isn't a problem.
Both AC and Cruise Control work with my current bench flash. I don't care so much about cruise control, but AC is a must in AZ.
Ideally, I would want a shop to dyno and tune my car as well. The car runs extremely rich currently.
12 Honda Accord
Old 10-12-2015, 07:11 PM   #5
I like your stand-alone ECU project .Would it not be easier to resolve the rich running problem ? If that is the only problem,it may be easier to solve/hack than a stand-alone ECU?
For example, could it be as simple as using different injectors and using the correct air filter? Or just getting the injectors cleaned and maintained - easy diy job.
Old 10-12-2015, 07:19 PM   #6
Top_Ramen's Avatar
AEM EMS? Have a couple friends that use it but unfortunately they're not Porscches
'99 Porsche Boxster 986 - weekend car
'04 BMW 645ci e63 - daily driver
'98 BMW 528i e39 - dog carrier
Top_Ramen is offline   Reply With Quote
Old 10-19-2015, 12:16 PM   #7
Stand alone ecus do not have OBD2 integration. You may be able to pass a sniffer type test but a 96 or newer vehicle needs to have a properly functioning OBD2 interface.
Off road use only.
MaxD is offline   Reply With Quote
Old 10-19-2015, 12:51 PM   #8
Hi Crono0001,
check this: https://shop.vems.hu/catalog/vems-p-48.html
Fully programmable and can be individualized to your needs.
Regards
Markus
Old 10-19-2015, 01:14 PM   #9
The Radium King's Avatar
if you kept stock computers then you have a 5.2.2 dme - same as a 1999 996 3.4. get a shop with a pst2 to push a 996 flash on your car (get a row 996 flash to avoid issues with catless exhaust). that'll have you in the right ballpark. even with a .4 displacement difference, the ecu should be able to keep you running at stoich in low load situations without hitting the trim limits, and keep you a about where you want to be at WOT provided you are metering air properly - if you have a pst2 or durametric check your rkats and fras to make sure fuel trims are ok.
once you have the dme fueling you properly you can try an aem unit. they intercept the maf signal and send 'massaged' info to the computer. the computer will still use the o2 sensors to trim fueling to stioch at low load, but the aem unit will allow you to lean things out a bit at wot - more power, better fuel consumption. if you are feeling really ballsy, note that the aem unit is just a really expensive variable resistor, so try putting a variable resistor in there instead - some searching on the net should get you all the info you need.
