Old 09-30-2015, 12:48 PM   #1
Where is turn signal relay located
I have a 1998 Boxter and want to change out the turn signal flasher relay to a louder one. Where is this relay located on the car....Thanks
OBIEONE is offline   Reply With Quote
Old 10-01-2015, 02:53 PM   #2
1999 base
Meir's Avatar
flasher is located on the relay box, just above the fuse box on driver side kick panel.
Old 10-13-2015, 01:05 PM   #3
Thank you for responding.....i found the area above the fuzes where there are some relays located. By chance, would you have a diagram which relay is the one for the flashers....
Old 10-13-2015, 03:37 PM   #4
PaulDash's Avatar
Bentley manual shows it as #3 in the middle of the top row. YMMV.
Past: 944 NA white '86
Present: 986 black '98
Future: 959
PaulDash is offline   Reply With Quote
