Old 09-19-2015, 12:53 AM   #1
Exhaust muffler
Hi
I found out that the Rear Exhaust muffler on my 1997 2.5 986 is going to split soon
it is rusty " rotten " around the edge.
I found a new muffler from a 2.5 986 from 2000.
Looking on available mufflers on the Internet it is always mentioned model 1996-1999.
Do anyone know if there is a difference between the 1997 muffler and the 2000 muffler,
or will it be a strait bolt on?
BR
Barthol
barthol is offline   Reply With Quote
Old 09-19-2015, 09:38 AM   #2
BYprodriver's Avatar
You will also need the 2000 & newer improved mounting bracket.
Old 09-20-2015, 02:21 AM   #3
Hi Again.
Picked up the used muffler today at a bargain 30 GBP
It actually turned out to be a 99 model, meaning that it is identical to mine.
being that cheap I will try to modify the " sound" of it. that means welding stainless by pass pipes on it connecting the inlet to the muffler to the exhaust tip.
Using a magnet it looks like the muffler is made from "normal iron" while the exhaust tip is made from Steinless steel.
Is this correct?
it definitely makes the welding easier as I already have a mig welder with co2 .
BR
Kim
Old 09-20-2015, 03:00 PM   #4
njbray's Avatar
I am pretty sure the whole muffler is Stainless Steel. With a little work they polish up well.
Don't think I've ever seen a muffler made of Iron
njbray is offline   Reply With Quote
