Old 09-07-2015, 10:43 AM   #1
madmodz's Avatar
Replica/boxster airbag ??
Got another replica in for air suspension, new rims, stereo and alarm install. Customer wants me to get the airbags working. Problem is that its missing the side airbags on the door panels. The steering wheel airbag and passenger airbag are there since it's using the oem dash. The door panels are completely different. Can I bypass the side airbags by turning them off? From everthing I read is that if you have a fault none of the airbags will work.
Please no negative comments or bashing on the car-this is a technical question
madmodz is offline   Reply With Quote
Old 09-07-2015, 07:52 PM   #2
i believe the other airbags are "alive" even if the lights on....
the steering wheel airbag can be bypassed with a resistor so I assume the door airbags can be also
geetee is offline   Reply With Quote
Old 09-08-2015, 01:39 AM   #3
Motorist & Coffee Drinker
78F350's Avatar
This diagram may or may not be helpful.
I have the big fold out volumes if you need to see a particular schematic.
1998 airbag circuits:
From what I've seen it looks like the side airbags were optional on the '97 and '98 models. Maybe you could try the control unit and harness (if needed) from one of those early ones.
Old 09-08-2015, 06:15 AM   #4
Originally Posted by madmodz View Post
Are those all on a boxster chassis? More pics? link to who makes them?
Woody
Old 09-08-2015, 06:16 PM   #5
might the 'airbags' be for the suspension?
mcdandc is offline   Reply With Quote
Old 09-09-2015, 04:14 AM   #6
Hint: Take a minute to read the first post.
Madmodz: you bypass them the same as you would with any other airbag.
Old 09-09-2015, 06:38 AM   #7
On the slippery slope
JayG's Avatar
That looks cool.
More pics please
2004 996 Targa Tip
Instructor - San Diego region
