08-25-2015, 10:30 AM
02 Boxster lower control arm broke
Driving to work yesterday in my 02 Boxster and I hit the brakes for a light and I hear a loud thump and rubbing at my driver's side front wheel area. Evidently my lower control arm snapped. Anyone ever heard of this happening?
08-25-2015, 10:48 AM
Yeah, I've done that.
Holy crap. That is a pretty robust looking part, I'm surprised it would snap like that without a much harder hit than just braking for a stop. Sure you haven't had another impact recently that may have cracked it? Maybe some road debris like a truck tire tread or something?
1999 Boxster, Tiptronic, Hard Top, Arctic Silver with Boxster Red Interior
08-25-2015, 11:24 AM
How many miles on the part? :O
2006 V6 Mustang
2008 ML 350
08-25-2015, 11:41 AM
wow
Swodaw,
I am glad that the control arm failed while breaking for a red light and not during a spirited drive through a canyon...
08-25-2015, 02:12 PM
The car has 50k miles. I just bought the car in March with 44k. So, I don't know if the car has been wrecked. I don't think I have hit anything.
08-25-2015, 04:52 PM
Better check the torque of the bolt that formerly attached it to the chassis.
Is it from Mobile? Salt water corrosion?
08-25-2015, 09:43 PM
Wow! I never would have guessed. I see both the lateral arm as well as the trailing arm have both just snapped right off there.
08-25-2015, 09:48 PM
Wow. Never seen something like that before. Especially from hitting brakes.
Because the lower control arm has a bearing i don't think that too much torque could have caused that.
I think you should investigate the complete car for accidents of a previous owner.
Regards
Markus
08-26-2015, 09:04 AM
It is not unheard of for GT3 LCAs to break in that area from lots of track use. Hard to imagine it happening with street use only. Maybe lots of potholes?
08-26-2015, 10:34 AM
Regards
Markus
Is bearing Germ-english for bushing?
08-26-2015, 12:05 PM
Hi BYprodriver,
 - damn, you're right.  I've meant a bushing. Sorry.
Regards from Germany
Markus
08-26-2015, 03:45 PM
Hi BYprodriver,
Markus
OK, we like your input from the motherland, Danke schon!
I was wondering if it is possible to install a LCA in a bound position with enough torque on the bolt to cause this! Maybe with alot of corrosion?
08-26-2015, 04:57 PM
Wow, never thought a chunk of metal could break like that!
09-08-2015, 11:53 AM
Thought I would give an update, ended up having to replace the lower control arm, trailing arm, and had a bent tie rod. hopefully be back on the road soon...
09-08-2015, 12:50 PM
As Spendy mentioned, I have seen this happen on several Spec Boxster race cars. Some racers will replace the LCA's every two years as preventative maintenance.
