Old 08-18-2015, 07:28 AM   #1
Wheel securing bolt socket
Hi, I have a 99' Base and I am missing the socket to remove the anti theft bolt. Is this a generic Boxster socket or is it unique to the individual car?
Gary
GaryMulcahey is offline   Reply With Quote
Old 08-18-2015, 07:49 AM   #2
911monty's Avatar
Gary; The socket is not generic, they are designed individually. Check your tool pouch in the spare tire, hopefully it's there. If you have a Dealer nearby they may be able to help. Otherwise search theft prevention lug nuts, there is a tool you can buy to remove, but will destroy the bolt. Most people just remove the security bolt and install regular bolts. Good Luck.
Old 08-18-2015, 07:51 AM   #3
On the slippery slope
JayG's Avatar
if it is factory, there are many different ones.
A dealer should be able to remove it
Did you check the tool roll or the pocket in the spare tire cover
You can also do a search and there are some methods to removing them
Once removed throw them away and replace with regular lug bolts
2004 996 Targa Tip
Instructor - San Diego region
Old 08-18-2015, 08:10 AM   #4
My dealer allowed me to use his kit in the parking lot to find the correct removal socket, remove the 4 locks, and to buy replacement "normal" bolts from him. Unless you have expensive wheels or live and drive in theft prone areas ....
Old 08-18-2015, 08:24 AM   #5
I'm pretty sure if you have really expensive wheels, they'll hammer a socket on the bolt and remove it anyway. Speaking of which, my mom's 2012 Hyundai Genesis has those lug nuts that are completely circular on the outside, the key part is on the inside, which makes the hammer a socket on method useless, I guess. Pretty interesting!
hancock1701 is offline   Reply With Quote
Old 08-18-2015, 08:25 AM   #6
Thanks guys. Good info.
Just bought the car. A 99 with 57,000 kilometres. Good deal but has a few deficiencies like no tool kit.
My local guy down the road has the kit to take anything off so I will just order 4 replacement bolts without the security. I live out in the country so theft isn't that big a deal. I have dogs.
Gary
Old 08-24-2015, 12:19 PM   #7
amagalla's Avatar
You can actually buy the removal adapter from the dealership. In the states, it'll run you about $40.
Tony
Lapis Blue 03 Boxster S
Old 09-02-2018, 03:25 PM   #8
I'm having a hard time removing the wheel lug bolts using the factory socket wrench. They're too tight and wont come off even if I step on it. Any suggestions? Thanks
BoxsterHtownTX is offline   Reply With Quote
