Old 08-14-2015, 08:21 AM   #1
Fuel leak at tank connection
I have a NTM 2003 S, my IPM noticed a small leak where the fuel line connects to the tank. Has anyone found a way to replace/repair the connector, or does the complete line have to be replaced?
Thank for any info.
mcdandc is offline   Reply With Quote
Old 08-14-2015, 07:16 PM   #2
Do you have a picture of what it looks like? You can probably cut off the connector and put a new one in with a heat gun. I've done this before on in a different location. You can also get a compression fitting and just replace a portion of the line. If it's the connection that I'm thinking about I can send you one if you pay for shipping.
martsink is offline   Reply With Quote
Old 08-15-2015, 05:08 PM   #3
Registered Boxster abuser
healthservices's Avatar
pull the connector off and see if you can fish out the oring, match it and reinstall
Old 08-18-2015, 04:28 PM   #4
Thanks for the info, it seems to me that a splice in the fuel line would involve the least chance for errors. My main concern is matching the connector fitting, I have a request into the fitting manufacturer so hopefully they can supply a perfect match.
If you think you may have a matching connection, I can repay you the shipping via PayPal.
There may be a light at the end of the tunnel, thanks.
Old 08-18-2015, 04:33 PM   #5
I just took out my carbon canister so I have a bunch of connections from that. They are 90 degree quick connect fittings. There are two square white buttons on each side that you press to disconnect them. Here's a random image I found online. Is this what it looks like?
