07-26-2015, 12:23 PM
Wiring help
I'm looking for any wire behind the dash that needs to be live permanently (ignition off) to wire into a blank switch in my centre console for something that I am doing. My cigarette socket is not permanently live, I think this is because I am in South Africa and it is country specific.
Secondly I'm looking for another wire that is ignition switched, is there any wire that leads to a spare fuse in the loop behind the dash? I can use the cigarette socket line, but I just don't want to over load this circuit as I already have one or two things running off of it.
Thanks in advance!
de-snorkeled, clear lights, sports exhaust, zeintec hard top, zein wing, B&M short shifter, DesignTek lowering springs, DesignTek carbon fibre strut brace front and rear, 18'' carerra 5 spokes, semi slick tyres, entire soft top delete, engine cover delete,red console,L&N deep sump, volo performance chip, raptor shift light, de-cat'ed, OEM GT3 bucket seats.
07-26-2015, 02:06 PM
There is a connector in front of the gear shift under the console that has switched and unswitched 12v
do a search for telephone connector and you should find info on it
07-26-2015, 02:09 PM
Rookie
Test lights are $5 at auto parts stores. It pays to always verify power before you go tapping into something.
07-26-2015, 02:44 PM
It also pays to PM Particlewave before touching anything electronic!
07-26-2015, 03:35 PM
one more thing, those blank "switches" in the center console and around the radio are not switches, but blank plates
07-26-2015, 10:57 PM
Thanks guys, I have a multimeter so will check before I Tee into any wire and make sure I'm happy. Just used the term blank switch to get my post going, I have already got a oem switch that I will swop out into one of the blanks spots.
07-27-2015, 10:21 PM
Connector in front of shifter
Is for the cell phone option, you should have switched and unswitched +12V there. Remember it is not how much voltage you use it how much current. WHat are you planning on powering there ?
07-28-2015, 09:35 AM
Hijack: does anyone know the fuse/current rating on the phone connector off the top of their head? Do the switched and always hot 12v of the phone connector go through the same fuse?
07-28-2015, 05:24 PM
inveniam viam aut faciam
They do not got through the same fuse, they are separate from everything else and I believe they are 7.5 Amp fuses. Ignition (term. 15) is green/black, and constant (term. 30) is red/green. At least that is what I remember off the top of my head from pulling apart a bunch of Spec Boxster harnesses. I would have to look up what fuse numbers they are.
These are great to use for all sorts of accessories.
03-27-2016, 05:59 PM
Qmulus,
Need your help with my 12v Power Steering install. Based on a post I saw here I tried D4 on fuse box in the Driver side footwell, however that is 12v Batt and remains On all the time. Unfortunately I wired everything from a junction stud I installed just behind the CD cubby. Now I don't have 12v Sw so need to find that. Ideally if I can find it in that vicinity, I can easily route it to my junction stud.
Could you help? Thanks!
03-27-2016, 06:23 PM
German cars follow the Bosch wiring standard and in all of them a solid red wire is always hot.
And a solid brown wire is a ground.
Solid means no stripe.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
03-27-2016, 06:26 PM
I think I found 12v Sw right where I need it!
In the center console area there is a unused 4 pin connector, that I think is for the phone option. This connector has both 12vBatt and 12vSw. The RD/GRN wire is 12vBatt (continuous) and GRN/BLK is 12vSw (Switched). Checked it with the DVM, and confirmed.
Now I can just wire from right there...
