Old 07-03-2015, 07:43 AM   #1
bwillia080261's Avatar
Bad couple weeks for the Boxster
2001 Boxster S 70K miles
Last week it needed a MAF and an AOS after the Check engine light came on.
This week it needs a primary CAT and two O2 sensors!
Can you say $3500 down the crapper!? Sigh!
bwillia080261 is offline   Reply With Quote
Old 07-03-2015, 07:09 PM   #2
Artist, 986S tinkerer
NewArt's Avatar
I get the feeling that these things are linked. Hip bone connected to the thigh bone...
Just a hunch but when my car blew a smoke bomb at the track a couple of weeks back, steved0x mentioned that a slight oil overfill had caused the same situation with him. That event threw a code saying "cylinder misfire could cause damage to catalytic converters". I think that blowing oil through the system is generally to be avoided.
Old 07-03-2015, 07:11 PM   #3
NewArt's Avatar
Oh BTW, I picked up a used primary cat of ebay for cheap. Works fine.
Old 07-03-2015, 07:51 PM   #4
EJ-Fresno's Avatar
Why don't you install cat-delete pipes? The pair costs like $190.
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 07-04-2015, 08:56 AM   #5
Unfortunately here in Colorado we have an emissions test requirement with visual inspection.
Old 07-04-2015, 09:03 AM   #6
EJ-Fresno's Avatar
So do we in Cali. I swapped for cat-delete pipes and hopefully I'll get lucky for the smog test. Worst case I kept the stock cats to re-install them if needed. Or I need to find a "friendly" smog shop
2006 V6 Mustang
2008 ML 350
