Old 06-13-2015, 09:23 AM   #1
Vacume lines
Does anyone have or know for definite where the vacume lines go so I can check?
Specifically I've seen photos of the same engine but different vacume lines.
I've seen the rear plenum rubber have the check valve and line in it, I've also seen the front have it instead, also I've seen the rear rubber have a vacume line with no check valve and instead the check valve is near the aos on the splitter?
I just need to see a pic so I can make sure mine are right.
Cheers
Barks
barks is offline   Reply With Quote
Old 06-13-2015, 09:26 AM   #2
lkchris's Avatar
The vacuum lines are likely different among different years.
In USA at least, we usually get a decal in the engine compartment indicating routing.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 06-14-2015, 07:18 AM   #3
thom4782's Avatar
You can download a PDF parts catalog from the official Porsche website. In the US, the catalog shows two different vacuum line configurations for 986s. Try this link: http://www.porsche.com/all/media/pdf/originalparts/usa/986_USA_KATALOG.pdf.
In the PDF search for vacuum. Good luck
Old 06-14-2015, 11:39 AM   #4
Excellent.
Many thanks
Barks
