Thread: Vacume lines
Old 06-13-2015, 09:23 AM   #1
barks
Vacume lines
Does anyone have or know for definite where the vacume lines go so I can check?
Specifically I've seen photos of the same engine but different vacume lines.
I've seen the rear plenum rubber have the check valve and line in it, I've also seen the front have it instead, also I've seen the rear rubber have a vacume line with no check valve and instead the check valve is near the aos on the splitter?
I just need to see a pic so I can make sure mine are right.
Cheers
Barks
barks is offline   Reply With Quote
